Wiring
bigkelk9
maybe if you would disconnect the led out of the tail light you wouldn't have the "back circuit from the led ".
then check the wires going to it .
life was simple when we used filament bulbs :oldconfused:
That was the first thing I did, but I figured it out.. stopped being lazy and just traced it back to my fuse pannel and how I wires that in..
Rottweiler
So tie my brake and turn together... makes no sense electrically.. that' where I'm trying to get some help.. how this one works is
White - brake
Red- run
Yellow -turn
Green - turn
Black - ground
You could wire the new light this way.
White - brake Tape up this wire from the new light.
Red- run Hook this to your running light red wire on the bike.
Yellow -turn Hook this to your turn single / brake violet wire on the bike.
Green - turn Hook this to your turn single / brake brown wire on the bike.
Black - ground Hook this to any good ground black wire on the bike.
This should give you the turn and brake lights on the new light bar.
Where are you mounting this bar?
More pictures please.
If you need more light you could hook the white - brake to the same red wire as the running lights.
bigkelk9
Yeah I got it figured out.. didn't install it yet because I'm trying to find where I can get jst connectors and the jst pins to do it clean.. I'm mounting it under the rear fender.. it'll contour with the fender and not be too noticeable.. this is how I had my fury, but on that I got rid of all the factory lights
Rottweiler
WSW Curtis may have the JST connectors? A lot of us on here have some old used ones. I replaced my main harness and kept the old. Good luck.
bigkelk9
I'll shoot him a text, didn' think to ask him or Donna, I've been looking in all the obvious places, places that supply wires and connectors.. lol
