Gmutoagrsv
How or where do I get it tested? And link for the plug and play?Have it tested, if replacing get axles direct plug and play 2 year warranty
http://www.wildsteedworx.com/index...._info&cPath=65_68_173_82_203&products_id=1659How or where do I get it tested? And link for the plug and play?
I thought I had a link for hairs but I’m not seeing itI'm assuming you did not have the ehc tested? My guess is it's time to order axles ehc.
I know this was mentioned before and I didn’t read through all the post. I had the same problem on the pitbull awhile back. After about 6 months of trying everything I found one of the pins on the jst connector was loose. It was still seated in the connector so I wasn’t easily noticed. I found it by gently pulling on the wire and the pin wasn’t locked in and it pulled out. I replaced the male pin and sure enough problem fixed.I thought I had a link for hairs but I’m not seeing it
Which part of the issue what are you having? Was it the headlight issue or the not starting?I know this was mentioned before and I didn’t read through all the post. I had the same problem on the pitbull awhile back. After about 6 months of trying everything I found one of the pins on the jst connector was loose. It was still seated in the connector so I wasn’t easily noticed. I found it by gently pulling on the wire and the pin wasn’t locked in and it pulled out. I replaced the male pin and sure enough problem fixed.
It was a headlight issue. But it could also cause starting issues pending which wire and if it’s making contact.Which part of the issue what are you having? Was it the headlight issue or the not starting?
Also have you checked the headlight connector? They are known to meltWhen the issue started the bike ran fine. It was only the light.
Yep should never use a 100watt bulb anyway that power also exceeds the JST connector under the tanks amperage as well. BDM also listed in the manual to never exceed the 55/60w bulbs.I had one client, who had a little bit similar issue with my EHC. The connector for low beam and high beam was defect, following that the high beam and low beam contacts were connected together and the bulb used more than 100 Watt instead of 55/60 Watt due to the unwanted connection. The result was that the main polyfuse had tripped after some minutes and had switched off until the EHC was cool again. A change of the connector had solved the issue. I would suggest to check the con as well.
All the best!
Axel
*update*
So assuming the EHC is bad I went ahead and put the bike back together and still have the flashing high beam indicator and unable to activate high beams on the switch started the bike up it ran for a few minutes and then died and will not start the EHC Has red lights flashing back and forth on the top two and on the bottom row the fourth light is red so I’m wondering if it was dying the whole time and started off with the high beams and then died the rest of the way. Any ideas or thoughts?
Also I noticed you never answered me did you put a Multi-meter to check the voltage to the headlights? Without that step we can't help you.So you got 12v on the yellow wire and you cant get any voltage on white?
There's really no way to remove the potting from the EHC to look inside. It is possible your high beam Relay is shot but I did you try jumping the pins in the hand control board to see if it's not the board?
