Well looks like you definitely got an issue with the headlight wiring, shorting out somewhere. Gonna have to start at the plug and work your way to the connector under the tank and keep going backwards.![]()
This is after I got the ehc back. 12.24v out of the battery with nothing attached. I have it hooked back up to the tender. I Haven’t pulled the headline apart again but will be soon. Tried to start it but it just cranks and cranks.
Good luck!
Also noticed you got another light on? Before you said it was the bottom one and the top two. Now there's one in the middle. Lol
