I have used both, never tried doubling them up though. Now you got me thinking...So once it's at 1k then warms up and drops RPM to blinking range it still won't raise the idle if you turn the idle screw a bit?
Those tapered ones I've never had much luck with I prefer the old skool flat style (non-tapered) and just double them up.
These are the ones I get and anytime the exhaust comes off I just replace them so I keep the pack of 10 on the shelf. Haha
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/191181084529
What pipes are you running ?I’ll see if I can get a set at HD tomorrow and swap them out. Looks like if it doesn’t clear up, I’m riding the busa with momma on the back...nah, I’ll drive first. Just nothing like riding my dog since I got the first one.
V&H BR with 31/76 jets baffledWhat pipes are you running ?
Do they have 02 sensor plugs? Reason I ask it that my old pipes had a crack in them around the plugs or they could be loose. It’s a long shot but worth askingV&H BR with 31/76 jets.
Not that I remember but I will inspect them good tomorrow. Hopefully HD has a set of gaskets.Do they have 02 sensor plugs? Reason I ask it that my old pipes had a crack in them around the plugs or they could be loose. It’s a long shot but worth asking
I just looked at my V&h pipes 2/2 and they don’t have them. Would try what Eric is suggesting and go from there good luckNot that I remember but I will inspect them good tomorrow. Hopefully HD has a set of gaskets.
Will do Paul. 3am comes by quickly so I’m gonna catch some shut eye. Thanks allI just looked at my V&h pipes 2/2 and they don’t have them. Would try what Eric is suggesting and go from there good luck
When you put in the new carb I'm gonna guess you replaced the carb gasket too?Will do Paul. 3am comes by quickly so I’m gonna catch some shut eye. Thanks all
Exhaust gaskets look good and I did not try cracking the throttle but will now. I won’t have new gaskets until later today but here’s a pic of the pipes and exhaust ports. White ashy look to it.When you put in the new carb I'm gonna guess you replaced the carb gasket too?
It seems funny to me even if it's an exhaust gasket that your having this much trouble. I would think spinning the idle screw a bit you should still see the change in idle when warm.
Also I've noticed once that tach starts blinking it doesn't stop until I crack the throttle a little then idle just sits back at 1k. I think it's just because that thing really only triggers with >500 RPM differences.
Exhaust gaskets look good....when I say crack it I don't mean anything north of like 2k RPM or anything. Just a slow twist of the throttle is fine too.View attachment 53991
Exhaust gaskets look good and I did not try cracking the throttle but will now. I won’t have new gaskets until later today but here’s a pic of the pipes and exhaust ports. White ashy look to it. View attachment 53990
I should give John a call. I’m going to Deltona and the bike will sit there four days until I get back there on Friday.Exhaust gaskets look good....when I say crack it I don't mean anything north of like 2k RPM or anything. Just a slow twist of the throttle is fine too.
That looks a little lean to me! Haha. But your running a 31/76 so it should be the right stuff! It could just be residue from the old carb that wasn't running right since it was broken and it hasn't ran enough yet to give you an idea of how it's doing.
If you want to be sure once you get it all back together you can reset the carb to the S&S recommended settings and just start from scratch again not like it should take more than a few minutes!
Good luck! I hope you get it this time around! I know you rode it before so should be good enough to get you around Daytona anyways, right? Just Bring a screwdriver with you and let John Sachs play with it! Haha
Thanks again John, always good talking to you.Hopefully it will fit on Rob's (Road Hog) dyno. He should be able to make it spot on unless there's another problem. He's at the Cabbage Patch.
John
patience grasshopper, see how it works out ?Hallelujah fellas. Followed advice from the forum and Kers instructional video, pun intended, and voila. Running like a CHAMP RIGHT NOW. I will test ride tomorrow and small tweaking but it’s good now. I think I had it way to lean and was misreading the carb guide. See y’all in Daytona and thanks for the help.
BoomHallelujah fellas. Followed advice from the forum and Kers instructional video, pun intended, and voila. Running like a CHAMP RIGHT NOW. I will test ride tomorrow and small tweaking but it’s good now. I think I had it way to lean and was misreading the carb guide. See y’all in Daytona and thanks for the help.
