FRUSTRATED BAGGER OWNER!
sounds like the only thing they could do better would be if they cover the costs over at Dirty Rat. hope all works out for you.
BULL74
Im sorry I didn't realize they did a harness swap, what about 02 sensor?
The crank sensor is actually one of the parts they changed out. They initially went with a wires plus but then took the stock harness off of another bagger they had, installed that one and then went with a wild steed EHC as they decided that was a better way to go. I put in a call to D O C 's but haven't heard back yet.[/QUOTE]
Vicki
[/QUOTE]Changed that out to. They found that 3 of the 4 lifters were S&S and the other was a brand called Andrews I think. They put new ones in and both cylinders are firing now. The check engine light came on again stating bad sites. They checked the plugs and one had oil on it pretty bad. They will be tearing down the other cylinder tomorrow. Thanks for checking up!
BULL74
Sent from my SAMSUNG-SM-G920A using Tapatalk[/QUOTE]
sounds like they are getting you in the right direction,glad to hear
