Brandon Downey
When I bought my 2007 Mastiff back in August, the air ride suspension would not air down/deflate. It aired up just fine though. I confirmed it was not the high/low switch by doing a function check with the high beam light, and the switch worked just fine turning that on and off. So I knew the switch was good. I searched and read everything on here that mentioned the word air ride, and unfortunately I wasn't finding a whole lot of info about the system and how it works. A few weeks ago I stumbled on to an air ride solenoid listed on Ebay through Derek and Donna, and after confirming that this should fix the problem, I ordered it. It arrived last night and so I HAD to tear into it and see if this was the fix! After wrestling with my side covers for way too long (the rubber mounting grommets are shot and need replaced or upgraded), I found that my solenoid was unplugged. Upon further inspection, it appeared that when it was originally installed there wasn't enough slack left in the wiring to reach the solenoid properly. Between the tension from the lack of slack in the wiring and the vibration of these bikes, I can only theorize that these two factors combined caused the clip portion of the electrical connector to break allowing the wiring to come unplugged. I created the necessary slack in the wiring and plugged it in, aired it up, and voila! She aired down! Although I created the needed slack for the wiring harness to reach the solenoid properly, with a broken connector there was nothing to prevent it from coming unplugged again. A zip tie was the solution here, and now the connector can't come unplugged on it's own. I am one happy Dog owner! I will post any repairs/problems regarding the air ride suspension in the future in hopes of providing needed help to others on the forum. Now to hunt down the side cover hardware.....
