Air Ride Suspension Fixed!
Ed U. Cator
Higher Ed.
The air solenoid module's electrical connection uses 2 header pins for the connection. It's not the best choice for something that vibrates a lot. I removed them and soldered wires directly to the circuit board. From there I used a locking Molex connector, should I ever have to easily disconnect wires.
Cdog07
B
Mine came installed from the factory, so my air up process is to hit the start button which puts it in air ride mode, then the high/low beam buttons air it up and down. After 10 seconds of inactivity it defaults back to normal operation. Yours was installed by someone or some shop after it was purchased which is why it has the toggle switches on your side cover.
Brandon did you say that the air ride procedure for your bike was to key on, then hit start button (once), then hit hi beam to air up?? Just checking cause mines been down for other problems and I actually forgot the procedure. It’s hard to find any info on the system at all. Mines a 07 k9 with factory air ride
Bazil
What could be a couple reasons the factory controls could not work. Would it be the switches on the handlebars or the ecs?
