I'm not seeing the crank sensor
You should not have removed that.
man you should not have removed that.
That's what I thought but was told it was not there and to pull the side cover basicallyCrank senser is on the front of the motor. You showed a pic of it earier.
Wow that’s a mess,
You are correct, I haven’t seen anything that resembles and ignition module in any of his pictures?I'm pretty sure that square gray box is for turn signals and brake lights.
It isI'm pretty sure that square gray box is for turn signals and brake lights. I'm gonna step aside and let Paul help you. It gets confusing when to many people get involved.
Correct, see the picture that I attached with the silver box with the wires? That is your ignition module. That ultima system is for basic setups (minimal) functions and are used with another controller for the turn signals horn etc.I guess I thought that was the module.. yes I still have the other one.. so switch it out for the one that I'm tryna use now.?
Check with Derrick and Donna for the coversDoes anyone have any place I can get a right side battery cover? Mine was missing when I got the bike
