Hi guys,
It´s long time that I was in the forum due to much work here. I just want to give an update of the EHC:
I had a discussion with Curtis regarding the EFI bikes, cause there is still the challenge that the original EHC had divided the speed signal from the sensor to 1:7 . In my EHC I have made a bridge between the speed sensor and the EFI module. It works almost ok, but the result is, that the EFI get 7 times higher speed signals from my EHC compare to the original EHC. I just have made a speed divider and have send a few samples to Curtis today. You´ll find infos of the module at:
Axel Joost Elektronik Speed Divider - Speed Divider Dieses Modul teilt das Geschwindigkeitssignal vom Radsensor oder Getriebesensor in einem einstellbaren Verhältnis von 1:2 bis 1:10 runter. Das Verhältnis wird im Modul gespeichert und kann vom Anwender jederzeit wieder geändert werden...
www.elektronikbox.de
I´ll offer the modules for EFI bike user for a lower price if the samples are working w/o issues. The modules are easy to implement in an EFI bike. You just need to cut the green cable from the EHC to the EFI controller, hang the module between EHC and EFI and connect it to plus and minus. That´s it.
For later EHC´s I´ll implement the 1:7 divider in the EHC and declare EHC-E if the samples are working.
All the best and always a safely ride!
Axel
