Rake is not the most important measurement.I'm not an expert on the subject, but it is my understanding that those few degrees in the tree are there to get the trail to an acceptable number. A 0 degree tree would probably adversely affect the stability of the bike.
Welcome from NJGood morning, i'm a french and i have a Ridgeback.
Its possible to make a triple tree with 0 degree ?
Thanks for yours answers.
Jérome
When you USE raked trees, you change the rake and NOT the trail. That WILL hurt hi-speed handling. 0 degree trees WILL help handling.I'm not an expert on the subject, but it is my understanding that those few degrees in the tree are there to get the trail to an acceptable number. A 0 degree tree would probably adversely affect the stability of the bike.
John, I do believe you are incorrect about that. Rake and Trail are directly related.When you USE raked trees, you change the rake and NOT the trail. That WILL hurt hi-speed handling. 0 degree trees WILL help handling.
John
I hate to disagree with you John, but that just doesn't seem correct to me. Trail is the distance between the centerline of the front tire and the plane of the steering head if you draw a line through the steering head to the ground. A raked tree would push the front tire forward while the steering head would remain at the same angle. This seems like it would certainly change the trail. Again, I never claimed to be an expert, just my general understanding of the subject.When you USE raked trees, you change the rake and NOT the trail. That WILL hurt hi-speed handling. 0 degree trees WILL help handling.
John
Using a trail calculator and changing ONLY the tree rake also changes the trail.
Hey Jerome.... A lot of responses to your question already posted by some very knowledgeable members on this forum. Sounds like the consensus is that the handling would definitely be affected by this modification. The following is additional information / opinion and photo showing before and after (although it was questioned whether real or photo-shopped) from a thread started in late 2018. Only posting for your review and edification.... Hope it helps.....Good morning, i'm a french and i have a Ridgeback.
Jérome
