Tach reading lower rpms than bike is running.
06bigdogk9
Hi, I have an 06 K9 carburated, has the new EHC, recently started reading about half the rpms it's actually running, lights flash at idle because of it. I thought it was a coil issue, so I replaced that with no luck. Any ideas? Maybe a crank sensor? Thanks in advance
mleach72
Was the ignition changed recently?
mleach72
I upgraded the ehc last year, I believe it came with a new ignition then. Other than that, no
Did this problem start after the change? This sometimes happens when installing the thunderheart programmable ignition. It will cause the tach to read half or twice. Maybe changing the ehc can have the same effect. Anyways, you need to hook up a computer to change the tach calibration. You need a special cord and the thunderheart software.
06bigdogk9
Changed that about 4k miles ago, been fine ever since until the last couple hundred miles. Sucks, the nearest custom bike shop is over an hour away.
mleach72
Hmm, I don't know why it would do that all of a sudden then. I can send you the cord and software to try it, so you don't have to spend money on something that may not work. Where are you located?
Mickmorris
Well Known Member
Welcome from Florida! Check your tach ring. Could be the issue. Any loose connections there will make it do crazy shit.
