Need help. I have no head, running, blue indicator light on my 06 BD chopper. I am kinda clueless!
Jppumpin
Need some advice on the lack of frontal lighting on my 06 BD Chopper. Rears are working fine. I can’t seem to locate fuse box. Need some help
Jersey Big Mike
100K mile club
First thing I'd do is open the headlight bucket and check the connector for damage.
Also check the lights on the EHC (under the seat)
Stock there is only a pair of circuit breakers near the battery and they self reset usually. Other fuses are internal to the EHC and not user replaceable.
Jppumpin
Hey thank you! I’m drilling out the set screw and finding a tiny ease out today. That thing was already rounded out. Chingao!
Mikeinjersey
I'm late to the conversation but JBM is on the money. If your high beam indicator (blue) is blinking it usually indicates the bulb has both low beam and high beam filaments blown and the system is jumping back and forth trying to find one that works. When you get inside the headlamp of course check the bulb but also the connectors have been known to melt down and cause your issue. This is the an 05/06 manual which should help you get boned up on your bike.
