I have a 2001 Big Dog with the S&S 107 engine with a 5 speed. It's a recent purchase. It had this clutch creeping problem that made it hard to shift and hard to find neutral. I pulled the clutch out and discovered several warped steel plates, not burnt, just warped. I replace the whole clutch assembly with the same original clutch from Bigdog.net. I also replaced the short rod and bearing on the right side of the transmission, the clutch cable, and the long rod that goes through the transmission. I pulled the inner primary to replace the seal in the transmission. I double checked the alignment of the inner primary to the engine and the transmission and it was perfect. The inner primary slipped right in place without any resistance. With the inner primary back on and the clutch assembled, I was able to put the bike in gear and turn the rear tire with little resistance while holding the clutch in. I thought I had the problem solved. It's all back together and it's exactly the same way. What did I miss?
