Speedometer Moisture
Pitman
Does anyone know if the speedometer can be opened up and worked on . it seems the glass has a small crack letting moisture in I was thinking of opening it up and replacing the glass. are they vacuum sealed ?IMG-9357.jpg
Mickmorris
Well Known Member
Wow that’s a bummer! I can’t actually answer the question but I am sure one of these guys will know. Good luck!!
mleach72
Does anyone know if the speedometer can be opened up and worked on . it seems the glass has a small crack letting moisture in I was thinking of opening it up and replacing the glass. are they vacuum sealed ?View attachment 109606
I don't know if you can do that or not. I
would imagine that they make it very difficult to keep people from tampering with the mileage. Curtis at wildsteedworx.com has replacement speedometers. He can have them sent away to have the mileage set to your current mileage. Maybe use that as a backup plan. You can try to take your speedo apart and replace the glass. If you end up ruining it, then get one from Curtis. Just remember what your mileage was.
Eric at bigdogpartskingpin has digital ones that can be set to mileage as well.
SCC007
I was getting moisture in mine as well, turns out it was coming in at the rubber button for mileage/trip set. I was able to take the button off and using a hair dryer on the lowest setting (barely any heat) dried it out. Took a bit but it's an option. Then replaced the button carefully.
I ended up replacing mine with the Dakota Digital after a while.
Jwooky
You can but it not easy. You have to pry off the chrome ring from the back edge, go around and around 50 times.
it’s not necessary however to dry it out. Non of them are sealed well. You can pull the pug out of the back and put a vacuum hose on it.
Autometer used a grommet on the case instead of a waterproof strain relief. That combined with poor sealing at the bezel and the odometer button failure is what causes the issue. We break them down, clean everything, seal the electronics, install a quality metal waterproof strain relief, install a better quality bezel seal and purge them with nitrogen before sealing them back up.
Pitman
I will look to get it fixed properly in the next few weeks what is the cost of fixing it vs replacement ? one other question is the Big Dog Speedometers the only speedometer that will work or do any better looking aftermarket ones fit and work ? anyone ?FYI I don't like the Digital Big Dog ones.
CURDOG
Curtis (KaptinAmerika) provided a link, with pricing information, in his first reply.
