Arnie1340
I have a 2005 Ridgeback with 3,000 miles, when I put it away for the Winter, it was running perfect with no issues, a month ago we had people over the house and they wanted to hear this bad boy run! Fired up all good, and shut it down. somehow the key was left on, Today went to start it, Nothing except the left side turn signal was flashing when I hit the start button. Checked the battery, All good 350 CCA. unhooked the battery, waited about a minute and hooked the cables back up, Same thing no click nothing except the turn signal, rotated the ignition switch key 3 times hit the run button and noticed the EHC indicator lights were all lit red with one or two green ones. at this point I stopped messing with it, Is there a reset procedure I can do or does it sound like the EHC is fried,
