Doogan
Have an issue brothers. I have no leaks from fuel system while the engine is running. When engine off, and fuel off, fuel will slowly drip from vent tube off the carb. When tank is low in fuel. no issue. When the tank is 1/2 plus, it will leak. Removed line to carb and with petcock off, fuel is slowly running through feed line. Assuming that the petcock is not sealing closed. Is the petcock able to be rebuilt, or replace only? Any experience with this?
