Back off on the cable adjusters, and un-hook the cables from the carb.Having to do some work on my S & S Carb, and I cant remember how I detached the accelerator cables from the Carb. Any suggestions. Thanks in advance
There are pins that hold the cable to the throttle lever, do those pop out?Back off on the cable adjusters, and un-hook the cables from the carb.
John
You have to rotate the cable to the groove area on the grip... the cable and brass ferrule will then come outThere are pins that hold the cable to the throttle lever, do those pop out?
[/QUOTE
I will try both suggestions tomorrow. Thanks
And you will drop the ferrule and it will roll to where you will search for it for 1 hour (at least that's usually what happens with me)You have to rotate the cable to the groove area on the grip... the cable and brass ferrule will then come out
And that (losing a ferrule) is exactly what happenedLoose ferrules can gain movement power when dropped and even worse, are known to become instantly invisible upon impact with any hard surface. It is said they will gravitate to any edge, crack or dark corner. One time I searched for several hours, finally bought one from a Honda mechanic, and two months later found the darn thing right under the lift. Always keep at least 5 or 6 in your toolbox because dropped ferrules will stay in your line of vision if extras are readily available.
So now I always put a towel on the surface below the handgrip.
