2005 pitbull. Spark plug wire install
Hey brothers and sisters. How do I replace the spark plug wires on my 05 pitbull? Do I have to remove the ignition cover? Is it easy to do? Thanks
mleach72
It's possible to replace them with the coil cover in place, but it's a lot easier to remove the coil. This means you have to remove the left tank to get the top motor mount bolt out.
mleach72
Simple as you think. You can reach behind the coil cover to remove/replace wires. Make sure the motor is cold tho....
Harry, the coil sits a little bit lower on the 117's than the 107's. There's not much room to get your fingers between the cylinders and the bottom of the coil cover. It can be done, but it's a PITA.
