averagejoe
Long story short, i bought a 2005 Ridgeback. Not running. The seller claimed it just needed the stator installed and he couldn’t figure out how to do it. I installed the stator. The seller replaced the ignition module, coil, Ehc with rip kit. While replacing the stator i noticed the crank sensor was physically broken so i replaced it. It is all back together and i have no Spark. I started tracking some of the wires as i noticed the brake lights were on all the time. So i found that the crank sensor was plugged into the brake wiring and the brake sensor was plugged into where the crank sensor should have been. I did find one spot where the wire loom from the ehc had a gash in it from a rough spot in the battery box that has gotten into a red wire. I’m guessing it was grounding out. I taped it up to do more trouble shooting. I do have power on the positive of the coil. As well i have the old ehc , coil and ignition module. I am wondering if going up the wiring wrong could have fried anything. As well as a wiring harness diagram could be helpful. Any advice would be greatly appreciated,
