S&s super g, fuel spray at idle
dtmmil
Been messing with my bike trying to get the ignition squared away, running it with no air cleaner on the stand. At an idle or higher idle there seems to ve a pretty good amount of fuel spurting out of the idle mixture holes into the throttle bore, enough that its puddling and running out the inlet. Is this normal? I can adjust the screw like 1/2 turn total but thats from running poor to running poor, with it approx in the middle its spurting the fuel.
SCC007
Definitely a problem. Suggestion would be to set it to stock settings and see if it does it. Next would be to do a rebuild.
Does it leak when not running and petcock open?
May be either float, or accelerator pump are not correct.
Pull the idle mixture screw completly out and inspect. If the tip shows signs of wear or pitting, replace it and the spring.
dtmmil
No it doesnt leak any other time, it just dribbles a bunch while running. I lowered the float to 3/16, and dropped the pilot jet one size, pulled the mixture screw out and the oring was out of the groove, i will get it running tomorrow and see what happens
At an idle or higher idle...fuel spurting out of the idle mixture holes...
I'd think an out of adjustment is the float level, to a loose jet and fuel being sucked up between the threads of the jet. But for you to watch 3 jet holes feeding idle, puddles, and not stall? How you determine a clogged carb needing a clean: is a no start, to hard start, or wont idle, choke keeps it running/off it stalls.
One or more of the jet holes are clogged IF hard starting, wont idle. Simple physics says vacuum is going to pull fuel out of 3 jet holes is the constant. No single jet controls idle or WOT. It is all 3 jets that are pulling out a fixed amount, and a tapered needle lifted out of the main jet determine the amount amount feed. For it to puddle, I rather physical watch it from where your standing. Got a video?
Don't go pulling the carb bowl off so fast. Lots of hidden evidence if the float level is off. One would show the level enter out at both ends. Things like dripping gas out of the air cleaner side. Next is excess gas entering an opened intake valve, goes past the rings, enter the crankcase, mixes with the oil.
So oil cap off, does it smell like oil, or has a hint of gas smell? Dipstick caramel slow is the flow or lots of drops off the dip? Smells like oil, then it is not an out of adjustment scenario.
... its puddling and running out the inlet... I can adjust the screw like 1/2 turn total
Air screw has nothing to do with overly excessive gas. It is at a preset turn out, and fine tuning from there of incremental turns from its preset, that do not exceed more than a half turn either way.
Answer this:
1. Does it start fast?
2. Does it idle on its own?
3. Petcock on, engine off, can you see fuel come out of the low and main jet holes?
4. The spark plug's porcelain nose is what color?
