Jersey James
Jersey James
Outstanding... After all that polishing ( a labor of love ). You may want to consider the magnetic S&S chrome head bolt covers. Again, just a suggestion. JJ
Ya i would do the cleaning stuff, no polishing though, no patience for that, and i live in gravel so its always dirty. No comp releases either, so easier yet! HahaIf you had the gaskets (Rocker box kit, Heads/Jugs, Lifter blocks and Cam cover) you could do this very fast. It takes more time to unwire the compression releases then it does the hardware. Cleaning the pistons, Valves, and putting new seals in take a little extra but not much.
Damn... like right on S&S numbers ...Used a old cheap digital tach around a plug wire. Played with the idle settings some.
Looks like I it seems happy at:
950 RPMs warm,
Accel Pump 2.0 turns out (S&S starting recommendation was 2.0)
Idel air Screw. 1.25-1.5 Turns out (S&S starting recommendation was 1.25)
Throttle stop, Just BARLEY over 1/2 (less then .75) turn after contact with throttle. (S&S starting recommendation was 1/2)
