2 into 1 Vance and Hines question
Trainguy
Chromeoholic
Steve or Andrew can better answer buy i'm running 33/76 on the jets with this 2-1 mod and my plugs look good:eek:
bigdogtech01
Will I need to change my jet out after
I cut my baffle? If so what jet will I
need.
Thanks
Jerry
Here in NY state, I run the stock jetting as long as you have your stock cam, heads and cyl. bore. Stock is .295 pilot and 74 main. Not sure about down there in Ga. Just have to try it and check the plugs and see how it runs down the road.:up:
BikersDream
We build what you Dream!
need.
Thanks
Jerry
Lets start with a 31/76 just to be safe. Take it for a short ride, then remove the spark plugs and check. Lets also start with a new set of spark plugs.
:2thumbs:
jerr-06k9
had a 600 cam put in no more
TP boxs and cut the end off the
baffle. It is louder but backfires
like crazy. It sounds like a log
truck, runs rough as hell. Any
information would be great.
I like it louder but deceale
popping is bad.
