3rd Gear slipping
Was riding on Saturday when all of a sudden 3rd gear seemed to slip when excelerating. All other gears seemed fine. Was wondering if anyone else has encountered this and if so what was the problem and how dificult was it to fix? Thanks!!
Mikeinjersey
My guess is that if you got on the throttle heavy in higher gears it would slip as well. Could be time to consider new clutch discs but I would start by adjusting the clutch before making any decisions.
Jwooky
You sure it’s not 4th?
4-6 are helical cut gear and side load the main shaft. This will slightly unload the clutch.
Typically a sign bearings are bad and you have sideplay in main shaft.
Jersey Big Mike
100K mile club
Hey as long as it's not like the old transmission repair commercial
First Gear........................ (pause) Here
Little Sluggish there first gear
Second Gear................. Here
Third Gear.....................
Third Gear.................... third gear cut out man.
