anyone had this problem after adjusting there clutch??
Nomad2day
Longhair Redneck Geek
You may need to play with the adjustment to get it right. Backing it off a 1/4 is a good starting point. Try playing with the adjustment try backing it off a little more than 1/4. See if that helps! You may just need to find the sweet spot. If trying the adjustments dont help then you may need to open up the primary and check things in there such as the clutch hub nut for being loose. If not that then check the clutch dome hight and clutch pack wear limit...
Try what Brew is saying here.
Just tighten the jam nut enough to hold, if it still moves loosen it and back the Allen screw another 1/4 turn, tighten the jam and check it again. If it makes no difference then look in the primary side to see if the clutch nut has backed off from vibration cause it will move in and out on the treads. Be sure your clutch cable has plenty of slack in it when you do your adjustment.
It would not hurt to check your primary fluid level anyway and change it out if it has not been changed.
Spineguy
Guys, im chaulking this up to such a newbie I follow directions to the letter. I went back and loosened the allen further. Re tightened everything and now it seems to be working fine! Neutral is a little harder to find sitting still but im ok with that!
Good first trouble shoot to solve on the new dog.
Thanks all..
Nomad2day
Thanks all..
Good to hear you got it not creeping when holding in the clutch.
Just a little blip on the throttle when putting it in neutral helps it fall into place as well.
nietoss
I would be careful though. And if u notice anything acting funny I would pull the clutch and at least inspect.. I had bolts come loose on my clutch basket and essentially shear off about 1/4 in of metal in the primary and I didn't hear and metal grinding till the last day. Before that all it did was pull slightly at stop and neutral was hard to find..
