BAttery on a trickle charger,,,,,,,Still wont fire
USCG23
The battery was not holding a charge.. I put a trickle charger on it and now it will not turn over!!!! Could it be the starter?? If so How much?? Alternator??
Thanks in advance!!\\\\
NIck
USCG23
Thanks Joe.. My bike has not held a charge after riding all day (about 200 miles)and then trying to ride 3 days later. Then she has a heard time firing..
mobsta
you say your battery is not holding a charge,what kind of battery and how old is it?
mobsta
i have a harley davidson battery in my bike that works great,some guys have the big boar and braille battery that also work well,the harley battery is rated at 430 cca's,remember these bikes need a good strong battery,if your riden 200miles or so i would think your charging system is working ok:)
Banned
it the bike charging while running.. check the V/R....breaker... is the stator outting out voltage???
Banned
these bikes take alot out of a battery to start it up,, if the charging system isnt working correct it will drain it fast..
mobsta
my quess is the battery,thats my quess and im stickn to it,you should also keep it on a tender,if you get a harley battery they will check your charging system for the battery warranty
Banned
check the rest 1st.. charge bat.. start bike, check if system is charging,, 13-14.5 vdc to battery.. if not check output from stator.. do a search its all on the site..if the stator is puttin out about 20-40 vac you should be good.. check to see if breaker or fuse is triped or blown.. if all this is correct check starter.
USCG23
Eric ,, I had a hard time starting her after 7 days , so I put it on a trickle charger and now I thought it was ready to go and it wont turn over at all... Click Click...???? I have no clue???
