Battery tender or not
redhog
I'm new to Big Dogs but I have seen a lot of post indicating that a battery tender is a necessity. I have a 2005 Ridge Back and after riding and leaving the bike setup for a week or so always find a weak battery and need to charge the battery before it will fire up. After firing the bike up , checked the voltage output and found 14 plus with the bike running. With the bike shut down and the key off and out, I see a slight voltage drain, is this normal?? The drain comes from a wire from a plug right in front the battery that is connected directly to the battery. There are two plugs right in front of the battery, I don't know what either does, again new to the BigDogs. Any info. would be greatly appreciated.
RCAdd1ct
JAFO
You need a tender for anything other than overnight.
The EHC is always "ON" waiting for a signal to switch a circuit on.
This listening for something to happen is a slow drain to the battery.
Fairless
Everyone at strokers believes in a maintenance charger, we can hardly keep them in stock (and my dad has one on every bike he owns). We use the "extreme charger" which everyone seems to be happy with.
hope that helps : )
barhopper
Another round please
I agree. Your battery will last years with a tender on it. :cheers:
Five Five
Never use one....no compression releases either...
1-1/2 years on my Braile Battery..
:2thumbs:
"Five"
BadBrad
2005 Pitbull
hope that helps : )
Hey Lena, What's different about the Extreme Charger compared to the cheapo at Autozone? I have a Braille battery that should be waiting for me on the doorstep today and want to get the most from it. I also have the Wire Plus on both our dogs. Do they eliminate the slow drain of a battery that the stock EHC causes? :cheers:
BigDogBro1
Made in the USA
PA Chopper
What if I disconnect the terminals or take the battery out of the bike over winter? Any harm to the EHC being unplugged for about four months? Sucks living in snow country.
BigDogBro1
Made in the USA
If your engine is fuel injected it will loose the learned FI map changes and revert back to factory default when reconnected to the battery. Will take about 500 miles to relearn the FI map changes again so I've been told.
My battery is removed for storage for less risk and the FI still runs fine after reconnecting in the spring.
redhog
Thanks Folks
What I've been reading in the posts indicates that the slight voltage drain is the norm for a BigDog. Again thanks
RRRUFF
redhog, if you are having to re-charge your battery everytime you take the dog out it maybe time to get a new battery. I put the HD battery in my 05 chopper this time and it really spins it over well. I also you the Battery Tender Jr. and has worked fine for me. Sometimes you have to make sure the connection is good. I only use it if the bike will be sitting for 3 days or more.
curt dog
My bike is the same way. If it sits more then 4 days the battery is week. I invested in a tender myself.
I use a Harbor freight $5.00 float charger and I just removed the original battery after 3-1/2 yrs and it was still working, just didn't trust it to go to Daytona. The new Magna Power Battery $59.95 spins the bike over much better, 310CC compared to the 270CC factory battery.
MARV
stock ignition needs 12+ volts to fire
my aftermarket dynatek ignition only needs 11+ volts so i can get away without a tender
Fairless
the xtreme charger repairs your battery. intelligent circuitry immediatly tests and evaluates the condition of you battery then sets the optimum charge rate its able to accept. it also willl not over charge the battery so your battery is back to its full potential quickly and safely. as long as the xtreme charger is connected, it continually tests your battery to maintain optimal bulk or float charge rate. the xtreme charger has the ability to extend the life of your battery by 5 times the normal life! the pattened PULSE technology minimizes the size of the lead sulfate crystals and allows the battery to accept as much charge as possible. the longer you leave your charger connected to the battery the pulsing continues to clean and repair!
Fairless
How much is that extreme charger lena and how many bikes will it charge at the same time
the singe charger is $100 (retail) $89.99 (for BDB members) and charges one thing at a time or you can get the double carger that charges 2 things at once - $189.99 (retail) $170.99 (BDB members)
