Bike dying
mobsta
how about the crank sensor?just a thought,gas cap easy fix.when it dies crack the cap open and restart bike:)
Iman
take the gas cap off and blow into it. it should vent, if not, unscrew and throw away and blow into it again. This happened to me 3 times till i figured out the cap was not venting
orion57
I was having a smiler problem but after the bike would die if I took the gas cap off and I could hear a slight boiling sound. So I checked my fuel line and it was resting against my front cylinder head. I readjusted my petcock and centered my fuel line between the cylinders and I have not had problem since.
BBChopper
Supports 2 Disabled Vets
Check your gas cap! some of them have a screw in vent that does not work. If you got it take it out and throw away the vent. Try riddin and when the bike starts to die down slightly unscrew the cap. Many of us have had this problem. It does let the tank vent and u get no fuel
V
X2!
BigDogBro1
Made in the USA
No kidding..
They said they probably get 2-3 bikes in a week with bad EHCs. I wonder how many didn't have a bad EHC? Apparently the people who make the EHCs arent producing as many anymore and Big Dog cannot keep them in stock.
I have been told that BDM says 80% or so of all EHC's returned to them as "BAD" from dealers are actually tested as good at BDM.
