clutch qustion
joshl
Alright how tight should I torque. The four bolts that go through the clutch and holds everything in place
joshl
is anyone still up
Just woundering if anyones up I'm trying to get this thing finished tonight so we can ride tomorrow
Are you talking about the four 5/16" bolts that secure the pressure plate/spring assembly to the clutch hub? If so, you should be safe at 18-20 ft lbs. I have the bandit clutch and the shoulder bolts get torqued to 25 ft lbs. I believe the stock bolts are supposed to be grade 5 so the 18-20 ft pounds will be fine. Remember to use lock-tight on the threads.
Little-Boo
:iagree: The Service Manual calls for 20, but I put 25 with lots of red locite.
Carlos :whoop:
Josh, I went ahead and copied all the pages out of my manual and scanned them and created a "How to" for all of us to use.
No where in the manual that I could find does it state how tight those pivot bolts (that's what the manual calls them) should be. But on the top of page 4-5 it states that they are 5/16 gd 5 bolts. In the back of the manual under "References" it has a torque guide and it states all gd 5 bolts should be 19 lbs. But if I was you I would use the recommendation submitted by Baker as stated above.
Have fun
http://www.bigdogbiker.com/forums/how/14750-bdm-clutch-primary.html#post214695
