05 Chopper RSD I have clutch squeal and binding when pulled all the way in. When you get ready to let the clutch out it squeals. I put a new throwout bearing , new baker 12 pk clutches and a new hardened pressure plate and it still does it. I have not put a diaphragm spring in yet. I have adjusted it accordingly several times. The carrier is not broke and the transmission shaft does not move. This thing is wearing on me and help is needed. Should I replace the clutch spring next?
