I have a 09 Big Dog K9, The shop is saying that i need to replace my wireing harness (ECH).I m understanding this is common with Big Dog motorcycles.My problem is I dont know where to buy the replacement parts.they are saying they can get me the complete wiring harness for 800 dollars.Will someone please tell me where I can get the correct DOCs, ESC or RIP kit that I need for my bike on line. thank you !Nice intro
welcome from Pa.
Most of us are replacing the ECH with other systems, DOC's ESC or RIP kits that are available now. The ECH has memory and requires constant tendering, these units that I mentioned are plug n play with their own wiring harness that plugs into the existing wiring throughout the bike.![]()
Doc's ECS is $675 on his website and all the controls are the same as OEM, its plug and play with great support if you need it, from here and from DOC, (Jeff).I have a 09 Big Dog K9, The shop is saying that i need to replace my wireing harness (ECH).I m understanding this is common with Big Dog motorcycles.My problem is I dont know where to buy the replacement parts.they are saying they can get me the complete wiring harness for 800 dollars.Will someone please tell me where I can get the correct DOCs, ESC or RIP kit that I need for my bike on line. thank you !
...I tried matches before, but nobody knows it anymore...http://www.elektronikbox.de/ebox_g_uk.html
Never seen anyone use a condom for size comparison on an item, of all the things lol....atleast it wasn't used!!
Yes, the M-Unit is a nice box and almost similar to my D-Box (http://www.elektronikbox.de/ebox_d_uk.xhtml) The M-Unit is about 3 times bigger compare to the D-Box but works ok. You might find infos about it on their Motogadget website.This could prove to be interesting. Seems like there are quite a few options out there for the EHC. What ever happened to the M Unit? I think that's what it was called.
The M-Unit could not handle the starter circuit after a year or so and it shorted internally and caught fire.This could prove to be interesting. Seems like there are quite a few options out there for the EHC. What ever happened to the M Unit? I think that's what it was called.
Will this way still be able to use key to start?Hi Lorenzo,
Yes, it´s not rocket science. Just connect pin A19 from the d-sub to 12 Volt (A3), what will switch on the ignition. A 10 Ampere fuse between might help in case of problems. For running the starter motor you will need a bridge between A3 (...or + 12 Volt) to A1 and B45/B29. I attach the schematic. However, it´s in this case a very "old skool way" without horn, headlight, rear light and flashers...
By the way, I like the pic what I found from an other threat of this forum. It´s a really nice old style schematic and it should fit on a beermat
Have fun !
All the best!
AXEL
