ENEED HELP WITH A CLUTCH
gilbert2312
ALOHA i need some help with a clutch. i have a 2005 chopper with the baker 6 speed and my clutch is gone the clutch hub was totaly seperated i need a new clutch hub and assembly i belive the part # is 120-000003-00 what should this cost me . thanks
P8RIOT
Depending on how far gone it really is, you may want to consider a non-BDM assembly as a replacement. Lotsa experience on the forum about that - I'm sure they'll all offer their two-bits. :up:
WB Cycles
Recommending the Bandit Bruiser for Big Dogs. Complete assembly and Carrier prices are :
BANDIT-110805 / Bandit Machine Works: Bearing Install in Carrier - $29.69
BANDIT-036301 / Bandit Machine Works: Bruiser Clutch (complete kit) - $277.50
BANDIT-036500 / Bandit Machine Works: Big Dog billet bearing carrier - $87.88
BANDIT-110854 / Bandit Machine Works: Snap Ring for Bearing Install - $2.25
Stock clutch for the the BDM 2005-2008 bikes (BDM122-000003-00) is $684.45
If the carrier is broken... that is a BDM problem. You then have 2 choices.
1. Call BDM and see if they will replace on their dime.
2. F that, get the banditt, speedier process that you can just do yourself and a much better setup in general.
Mickmorris
Well Known Member
Just found mine broke today. Been having issues with clutch adjustment. Sounds from primary and when checking fluid after changing 3 days ago found it black and metallic. Found this awesome piece of engineering
Oh shit! I bet you heard some sounds from the primary. Tore that up good. Call Eric @ HDM as HMAN suggested. Good luck! Start a new thread with your repairs. :cheers: :chopper:
