Fried something
Mickmorris
Well Known Member
The 3rd pic is the opposite side. It seems like someone has done some wiring.
Interesting. Can’t say I’ve ever seen a fuse box like that before. The third picture looks like your thunderheart ignition module is right on top of the EHC which is the little golden color unit with the sticker on it. Can’t really see the manufacturer date. But looks pretty old.
Snuffy
I would suspect that the pliers holding the terminal on the battery back home most likely shorted out on the frame and fried your harness and who knows what else. This looks pretty bad. Sorry for your luck. Best wishes.
Mickmorris
Well Known Member
The EHC has no lights on it to light up, however my ignition module light is not on. Isn't this light supposed to come on when the key is turned on?
Yes it is. And flash while running I believe. Can you snap a pic of the wiring connection to the EHC. The EHC you have is probably the culprit. BigDog.net sells a new EHC that is fairly easy to install if you still have the OEM connectors which I am guessing you do.
On their website all they sell is the RIP kit, I didn't see just the EHC by itself.
