headlight!!! yup another one!!!!!
outdoorsman26
I would contact a service center or even BDM and find out if they use a monitoring voltage.
If I get a chance I'll go take mine apart and see what it reads...
0that would be sweet!!! I will call a service center in da morn!! thank you again!!!!
Mr.Grimm
2008 Black Cherry Pitbull
I wonder if your getting back fed throught the negative wire.
check the hot wire directly to the batery negative.
see if you get any voltage
then check the negative wire to the batt negative and see what you get obviously you shouldnt get any voltage there.
if you do there is a short somewhere.
i hope this helps im an electrician trying to figure out electronics:cheers:
