Jay Dawg
Well I got back to the bike today, and I confirmed what I suspected, that because the swingarm is in the wrong location the belt has been rubbing the inside of the pulley/clutch rod cover. My clutch pull had been about 45 to 50 pounds, after removing the clutch cable, I found I could not pull the cable through the sleeve. Eventually I will be removing the swingarm, replacing the bearings,
the pivot shaft, pivot shaft bolts, and may be the frame adjuster. The work is going a lot slower than what I had hoped for, but there’s a lot of other things going on that it doesn’t allow me to spend much time right now working on the bike.
