Issues with Misaligned Swing Arm 06 Mastiff
Jay Dawg
Lots of work! Nobody said anything yet, but I bet that bike was shaking a lot missing 2 of those transmissions bolts. It's actually not super uncommon to see bolts missing.
If you ever feel the bike really shaking on the foot controls it's usually because of the trans bolts. When you put them transmission back in don't assume the original shimming was correct, I have never seen one shimmed correctly. It's a simple process bolt the inner primary on the motor and the trans and before you put any bolts in there check the gaps with a gauge and shim appropriately.
Not sure how the shocks are frozen, remember these shocks are PULL style, NOT PUSH. So it dampens as the swingarm pushes up, or PULLS on the shock. It's why almost all Harley Shocks won't work, they only did that hidden swingarm deal in the late 80's - 90's and why there isn't many aftermarket options. Not enough bikes on the road. Not sure if you did it at one point when you were messing with them but if that's how they were when you got the bike whoever adjusted those suckers didn't adjust them correctly one's longer than the other.
Using a dial caliper, I measured the difference between the shocks, the results are .0540" difference, I would not think that difference would cause what I have experienced. I would not be surprised if someone has gone into the shocks and just shimmed the hell out of the preload making for little or no travel, it seems nothing on this bike has been untouched...
Mickmorris
Well Known Member
I never had any unusual shaking with the bike, it shifted well and neutral was always easy to find, clutch pull was a real bitch, about 45 to 50 LBS. After I removed the clutch cable found I could not pull the cable through the sheath, so that was probably the majority of the problem there.
But break your fucking back if you hit a pothole though! :cheers: :chopper:Probably worse than a rigid! Lol !
