phatchopper300
I just wanta ride
I have searched the forum for my problem. With no results for a solution. I am hoping with the expertise on the forum I can finally get my neutral light working again. Here is some back ground info. New battery and have load tested it. OK. I have replaced the neutral switch and plug connector and had the wires on the tach ring resoldered by a computer store. Better than factory. Still no neutral light. I have had the light on a few times in the past but very dim and then it would go out. And not come back on. I do have a manual and have read all items about the neutral light knowing its not a EHC function but passes thur. I need help in checking the wires and connectors. Not sure how to use a DMM.(Digital multi meter) Thanks
