Paint Saver/Gas Cap Question
Looks very nice however in my case I have a split tank two Fills I don't have a paint issue yet I don't want to have one either this is why I pose the question are the big dog tank savers worth the money to buy them or is there something out there better. If install new will they do the job or do I need to RTV them in place if I buy them
Paint is fine no peeling or bubbling just want to prevent from ever happening this is why I want to install paint saver caps.
Mask off your tank around the gas bung before starting this procedure.
Trim the paint and body filler back about an 1/8" from the gas bung, if it isn't done already, then clean the bung up really well about a 1/2 inch down inside with sandpaper and out over the edge you trimmed back. Get down to clean shiny metal. Wipe everything out really well with Acetone several times. Use a two part Novalac resin, the link to the left is what we have been using, to seal down inside the gas bung where you sanded and up over the outer edge and over the paint about 1/8". If your using the paint saver you can go a little further but don't go past the paint saver edge or you'll have exposure of the Novalac. The novalac takes a few hours to set but can be sped up with a heat lamp or a halogen work light.
Once you have sealed the gas bung with the Novalac resin you don't have to worry about using the rubber seal and it actually makes installing the paint saver allot easier. Use a little petroleum jelly on each side of the rubber seal and the paint saver will tighten down nice.
This is also nice if you ever end up having a liner issue because the saver will not be a torment to remove.
Just be cautious when installing the pain savers. Make sure your applying adequate down force as you do not want the paint saver tool slipping off and scratching paint.
Novalac resins are a fairly new breed of epoxies that will withstand permanent immersion in harsh fuels and solvents. Most quality tank liner companies are using them now for fuel tank lining and many high end motorcycle paint shops are using the above procedure to seal gas bung paint edges before sending the tank out.
The above procedure is not something we have done once on a personal ride. This is a procedure we follow now on every BD that comes through our shop that shows any signs of paint saver sealant issues etc.
pknowles
RETIRED
Thanks for the in depth how to Curtis. Thankfully, I am still running the stock configuration on my 07 K9 with no issues.
Like many things on the BDs it's hit and miss. Many have issues with different things and many don't....lol. Fortunately, or maybe unfortunately for some, this forum is available to provide many different ideas and viewpoints to assist BD owners in they're quest to perfect their ride.
Scooter
Just received the ring extension this morning, fits absolutely perfect & looks even better!!!
You said you had my back and you did just that........... I will upload pics in a few days to show off your work.
Thank you my Brother
Badpit
Never use any sealant around the stock or any other paint saver(good luck removing if ever needed with sealant) If your cap is vented (do not remove the stock cap vent if problems vapor locking clean or replace vent) properly there should never be a paint issue the vent is there for a reason, unless your sloppy about filling the tank.
hc0183
I got your back. Give me a call Monday. 573-two four 7- 3 five o 8
Mr, Wright,
I would like to call you concerning a paint saver plate that you sell. I have a 2008 Mastiff that just started having the paint lift around the tank cap. What would be a good time to call you?
Thanks
Hardy Carper
aspen874
Business hours during the week is fine.
Mr, Wright,
Thanks
Hardy Carper
I can recommend Shannon's paint saver, I ordered one from him to put on my friends K9, simple to install and looks like it came from the factory that way. You won't be disappointed.
