this past winter i pulled my front end to grease my neck bearings. hooked it all back up now my signals are acting up. the right side comes on as soon as u turn the key. hit the left and the headlight goes out and then all 4 start flashing. i checked and rechecked the connections and everything is correct. and its not the ground either. have you guys ever run into this problem ?
