There wasn't a change in valve train noise so figured the pushrods were in adjustment. Each cyl took about 5 revs to hit 250 which is good but is that a conclusive test?did you check your pushrod adjustment?
another thing that would tell you if its something mechanical is comparing how fast each cylinder reaches the 250psi when checking the comression.
I just had a similar issue, tested the blue lead for the rear cylinder and it was chafed inside the frame, replaced that section of wire and the bike is running great now.
It's easy to overlook the obvious.I'm sure that I'm probably wrong, but, thinking back it was happening on my bike, ( rear cylinder misfiring ) Took a while for a dummy like myself to find that the plug wire was loose at the coil end. plugged it in good and tight and no more problems for last few years. Just sayin.
Ain’t that the truth!! When we have a problem with our bike, it’s. Always “. Oh no ! This is gonna be major expensive “ and we usually find that the last thing we’d think about is the problem!It's easy to overlook the obvious.
You might check the plug wire connections at the coil, or maybe even swap them and see if the misfire switches cylinders. New plugs? My 02 does that when the plugs get a little fouled.I'm having the same issue now... Did you ever figure out the direct issue here? One cylinder is great and the other hits about every 15 seconds or so. Compression is good on both.
Two fucking fifty says you do not let that engine builder out of your sight. 600 miles might as well say 60k.It is very conclusive.
.... then It's a bent pushrod.If the rear took two additional revolutions to reach the same pressure then that would mean that the rear cylinder isn't as mechanically heathy as the front...
I've changed plugs, coils, plug wires, plugs and continuity checked wiring and nothing. I've also performed compression tests. When running it yesterday, I pushed on both compression releases while it was idling. The back cylinder where I'm having the issue seemed weak. Do you guys think it could be the compression release not working properly?You might check the plug wire connections at the coil, or maybe even swap them and see if the misfire switches cylinders. New plugs? My 02 does that when the plugs get a little fouled.
