Rear suspension on‘02 Husky
roadie1389
Thanks @Mr. Wright. I read your scans and thank you. These got all the info one should need. But they do miss the spring pre load part. I’m starting to think that these might not have that option at all.
The spring is an "assist", the pre-load is based on the sag on the air side. So your air pressure will be different 1 vs 2 up. Once set, make not then you just check it from time to time.
JoeHawkins
Ok, so does that mean the spring pre load can’t be adjusted via the nut/spanner at all?
