Yeah I think your right. I let more out also. I'll air it up.25 psi seem real low on the tire pressure.
I like my tire at 35-36 ...it wears betterTire pressure, my 2005 Bulldog calls for 42 psi in the front and rear. You need to find a manual for the scoot.
If you have back issues you may also want to use a kidney belt.
At 42lbs you will wear the center down quick.... 36 gives it a more even wear and a softer feel.I like my tire at 35-36 ...it wears better
Yepp ...agreed..i get more miles at 36 and softer not sure why anyone run at 42 honestly.At 42lbs you will wear the center down quick.... 36 gives it a more even wear and a softer feel.
Little bit....but worth it I imagine. kinda nice not to have to worry about adjusting so when I ride 2up or tour I can set it differently.Pricey aren't they
Sent from my SM-N920V using Tapatalk
The point was he needs to get a manual so he has a starting point, to low tire pressure and a pot hole is a bad combination.I like my tire at 35-36 ...it wears better
They ride just like my 55 Chevy. A hot rod is a hot rod no matter the wheels. WWII airplanes were the first hot rods in my opinion.Big dogs are the hot rods of motorcycles they are suppose to ride ruff,vibrate,bark loud, and attract tons of attention it's all part of the experience just embrace it
Ok i would be intrested in either getting a new Solo seat that is going to be more confortable or getting my la Pera re done.Usually La Pera seats are really hard... we have 2 members who can make a seat for you...
Sterling seatsOk i would be intrested in either getting a new Solo seat that is going to be more confortable or getting my la Pera re done.
Yeah forsure can i get there details?
thanks
Ribs
He is a member on here, just search him.Do we have a contact?
ill look them up.
Ribs
Thanks it would be great if I could just get this seat modified or shortened and then re padded.I had Seatmaker (Scott) re-do my seats, he's a member also. Great price and quick turnaround. If Sterling Seats doesn't work out check out Scott.
