Starting problems
BadBrad
2005 Pitbull
Yeah, I held it against the cylinder and there was no spark. Now what ?
I would check to see if you have power coming to the coil. Need a volt meter for that. U might want to wait and get a little more feedback as I'm probably not the best or have near the electrical experience as many others on here.
RRRUFF
You said the red led would come on and blink. You are talking about the ignition module and not the EHC, right? If the EHC is lighting up when you press the run button then check the wiring at the coil. Check for loose connections and broken wires. Also check to see that you have power on the red wire at the coil when switched on and you press the run button. If all this checks out the suspect the coil or the cam sensor.
drbalazo
Yeah, the little sliver box on top of the EHC with the red light. I got it to run but it shut off again and that light does not blink anymore while cranking the engine. Any ideas? I really appreciate you all for helping a brother in need.
RRRUFF
If the red led is coming on when you hit the "run" button then go to the coil and check as stated above. You just have to walk it down until you find the problem.
