What Mike said... couple of choices:
1. MIke and Me ~ I like gas so I can pour it on the weeds. Best kind of magnets are from a chevy trans pan. So that now sits in the bucket and slosh the chain in the gas. I wouldn't get near the magnet but let the suspension wash it out. Dip all the parts in oil and assemble.
2. Clean as much as you can while it's together and run the magnet over the chain anshit, around the stator lugs, fuck the clutch and let the outer primary drain magnet pickup what remains.
3. The clean as much as you can routine above, then drain the oil hot so what debris floats in the oil, it comes out on the drain. Maybe flush with plain cheap oil a few times then use the syn when done.
Anal camp for me because I can see that crush on the roller to gear, roller to inner pin on the chain, and those [added] indents like an oil pump blade making that kind of [floating metal] stamping on the gears, rather than roll over clean oil all the time, right?
__________________________________________________________
So say photo/clock wise, 9 shows a gully wash call it. 12 o'clock spine shows it's torn up too. So for sure you are going to run a washer between the collar and inner face of the rotor, right? Stator wall wise, I'd clean the wall so I can stick a clump of clay on the back wall. I'd use WD and spray that contact side for the release on the rotor. Where am I over the magnet I run more shim between the collar and rotor?
Best thing to use is a 1/2" air gun and know when to stop before you stretch the threads on the spline. This way, no float with a taller wall or less gully with no wall to rest up against. I doubt a second shim would find a rub spot, nor take up chain slop to matter. Magnetism I can't say. Only your volt meter knows for sure.
