Tach going bananas
Matte Dog
I recently replaced my tach cluster and added a analog tach....went for a quick ride and the analog tach and LED tach are going all over...works fine until I get on it......connections under tank are fine....where else should I look so I can isolate if its a loose wire....
Thanks
BigDogBro1
Made in the USA
Did the original tach work fine?
I would start by asking the manufacture of the components why they don't work. They may not be compatible with the ignition tach out signal or your ignition unit.
