zombie
I developed a gravelly sound the other day and thought it was my primary. I drained her (clean fluid, no metal) I tightened up the chain inside, checked everything and made sure it was tight. Put her togetor and relubed it. Still had the sound. It is there under a load and while in gear, not while idleing. It's real bad when you let off the throttle. Drained the oil and the lower end, both were absent of metal shavings. Drained the tranny and have metal chunks in it. anybody rebuilt one of these? I have looked throught the forums and done a search but found nothing. I thought for sure a gearhead on here had rebuilt one. Any help would be appreciated, pictures would be perfect!
I tried to put pics in of the metal chunks but I'm not that computer savvy. They appear to be chunks of pin style bearings.
I'm wondering if I could go in from the primary where you adjust the clutch (mainshaft) and pull this assembly out completely and find my issue there or if I need to pull the transmission completely off and go from there. I have spoken to Baker and they sale each part separetely So I just neeed to know the proper way to start my attack on this
