Transmission mounting bolt torque
C
chaingunner
Guest
Finally got my ars off the Street Glide and decided to put the transmission back in the dog:D:D looking in the manual they say the mounting bolt torque value is 40 ft lbs.... that seems light for a 7/16 bolt. And NO lock tight.... What's your thoughts....
Thanks for the help.:cheers:
erldawg
When all else fails go with the manual. Mine has same torque spec. and no loctite
chacha
Chaff Your EHC!!
I use 45 lbs and nylocks -- so no need for locktight. The OEM nuts are nylocks, so I just keep 10 or so around -- always new, don't reuse a nylock.
