Wild Steed Works E.H.C. replacement vs Big Dog R.I.P. E.H.C. kit
willywill4765
To start off my ehc is going it has all the typical signs, so with that being said I need a new ehc and wondreing if any body knows what the differences are between the wildsteed works replacement ehc and the actual bigdog rip kit. I do like that all the warranty crap has been removed from the wildsteed one. But it looks like the RIP kit also comes with wiring. And my bike is a 06 Mastiff. Any advice would be greatly appreciated. thanks
What are the typical signs to let you know your EHC is going bad? I have an 07 bulldog in heaven starting problems now something's tripping my breaker and it cuts off
Sent from my Pixel 3 XL using Tapatalk
aspen874
I remember reading a while back that wild steed worx will check your old ehc if you send it out to them. Can someone confirm this or recommend someone that will. I'm almost positive mine is bad, just want to make sure before I order a new one.
Yes, they can do that, I shipped mine to them and it was determined that my EHC was good but on the fault codes it showed that the ignition switch was causing all my problems. I would have never figured that out had I not sent my EHC to them.
willywill4765
How did you go about repairing your ignition switch, I've read a bunch of different things on here even like going to tractor supply and buying one from them
aspen874
[I /QUOTE] I ordered one from Donna & Derick, fairly simple to replace.
