pressure release valve bubbles
does anyone know how to replace the bubbles in my pressure release valves 05 big dog mastiff
117 s/s i removed the split tank and noticed the bubbles down in the release holes
were broken or should say dry cracked
hey i was wondering if anyone new which push rod goes in what hole on my 117 s/s
i just replaced both compression release valves and noticed 2 pushrods are longer than the other
2 shorter ones. didnt realize this until i laid them out.if anyone knows i really need help on this
got to get it right thank you
Mickmorris
Well Known Member
The longer pushrod is the exhaust/ shorter is the intake. Front cylinder is longer to the front of the cylinder shorter back opening/ vise versa on rear cylinder
hey fellow bikers just replaced compression release valves both
putting all new rocker box gasket kit includes gasket plates
under both boxes. does anyone know if any gasket maker/sealer should be used also.
i noticed when i removed old plates it looked like some clear silicon very little was used.
just gotta get it right thanks
Mickmorris
Well Known Member
You might consider contacting S&S directly to be certain. This may help. IMG_7078.png
