While your bike is having one of its "no start" fits,
WHILE THE KEY IS STILL ON AND START BUTTON STILL PRESSED see if there's 12v at the "little green wire" on starter solenoid. "
I did and I do witht he newly acquired hi-tech $29 dollar radio shack meter that has already blowna fuse!
"Wiggle the wire around while you have the meter on it!
If you ALWAYS have 12V on that wire (start or no start) and you don't hear the solenoid pull in then you either have a bad starter solenoid or a bad ground. "
Key up, run button then start button and I was getting the CRV (comp Relief Valve) "click."
"You can check the solenoid with the "how to" I posted or if you're keen to use your new meter that can be done too!
Verify exactly, with the meter, what to check. I know you did this and I'm sure I followed directions which I might add is difficult for me, especially after a case of beer..
"It's a waste of time and money to shotgun parts at it hoping to find the right one."
Only changed out the circuit board and it was an upgraded board so no harm there but I do agree....
"The only way you're going to get this fixed is to logically go step by step ruling things out. :up: "
Thats part of my problem, I have no logic!
Dennis
