No Tach
Couple weeks ago the positive cable for my wire plus modules snapped off the battery and smoked out one of the modules. So I called Don at wire plus and explained to him what happened. He was cool about it and said that that really shouldn't have happened but said he has seen a few failures like this on some of the earlier versions like mine so he sent me a new one under warranty. I hook up the new one and everything works except for the tach. I might add when this cable snapped the bike backfired and died. So even though tachs work on pulses I knew that I could still check voltage on the wire coming from the ignition. Hooked up my meter and I am getting voltage from the ignition and when I rev it up the voltage drops like I would expect. So I will have to rule out the wire and the crane ignition itself. It looks as though the signal wire goes into the other module before it heads up to the tach itself. Do you think there is a chance that I smoked the tach board itself ? I also noticed that the high beam indicator is out as well on the tach board but I'm sure this has got something to do with the new style wire plus harness. The new one does not default to high beam like the old one did. This tach board is only about 3 months old, don't know if I'll spend another $90 bucks on another one. Can you guys tell me if when you turn your key on and hit the run button does the first tach light come on at all before you start the bike?
BadBrad
2005 Pitbull
Rocky (my wife) has the wire plus, but it's for an '03 and is a different model than what you have. You should be able to check the voltage coming from the wire plus to the indicator light. Have you checked that?
LDO
The Cleaner
Hey Brad, how'd the mod go? pretty simple?
Did you melt down those EHCs and make a paper weight?:lol:
sorry Al, didn't mean to drift O/T.
chihuasbigdog
LATINAMERICAN AFFAIRS
Alhall, I'm not able to help about mechanical or electric issues, but 6 months ago I bought from Biker Babe a new tach board just to find out the problem on my bike was one bad wire.
It was an 04 RB, so, if you want it PM your address and I will send you the old tach.
Maybe that way you can discard or find out if the led board is fu**ed.
BadBrad
2005 Pitbull
After swapping a couple of wires, it's just plug and play. Works great. Rocky is pleased and continues to show her gratification....:job::job::job:
The first hint of EHC problems on my '05 and I'll be giving you a call.
Not sure if the WP for newer models has the same pigtail that has to be wired for the indicator lights, but if it's the same, it should be easy to see if you're getting power to the bright light indicator. :cheers::cheers:
OK thanks chihuas, after talking to Jake I'm pretty sure that its the board thats smoked because of the way it shut down. But I don't want to loose any more valuable riding time I have left so it will have to wait a month or whenever we see snow.
